2
This discussion topic has been answered Discussion topic: National Lottery website thinks I am outside of the UK and blocks using their website
This message was authored by: Corkysdad
A UK National Lottery website I am trying to use says it looks like I am outside of the uk, when I am not. It then says I need to contact my ISP and ask them to update the registration of my IP address.
Re: National Lottery website thinks I am outside of the UK and blocks using their website
@Corkysdad
Are you using an iphone or ipad if so try disabling private relay or even a VPN if you are using either of these.
@Corkysdad
@Corkysdad if you are using Safari on an ios device this fault is caused by Apple's iCloud Private Relay either turn that setting off or use a different browser like Chrome.
