Discussion topic: MySky Sky Max Hub Port forwarding rules don't have any effect
Message posted on 17 Dec 2024 06:25 PM
I have managed to add the port forwarding rules via the MySky App for the correct device and the page says that there is 1 rule active (port 30000 TCP, Foudary VTT Server) . However, no matter what I do after this makes any difference and the port will not open. I have used various port checking sites along with my service not being available to determine that no mater what port rule I add that port remains closed. I have one of the new White Sky Max Hubs, I have reinstalled the app, I have restarted my device, applied all relevant inbound firewall rules to the same port and application, I have factory reset the router and done all of the above again with no luck. Please help me figure out what is going on.
Message posted on 18 Dec 2024 08:58 AM - last edited: 18 Dec 2024 08:59 AM
Re: MySky Sky Max Hub Port forwarding rules don't have any effect
Perhaps worth noting that where a Max Hub is in use on Sky Broadband there's a fundamental difference in the external network which may be having an effect entirely separate to what's going on with ports.
Message posted on 20 Dec 2024 11:29 AM
In your Sky Hub's web interface, under the WAN status section look for something that says "MAP-T Sharing Ratio" and can you please confirm if you're connected with an 8:1 or 1:1 sharing ratio?
Our systems should automatically detect when you enable port forwarding, or the IPv4 DMZ, and move you from a shared IPv4 address to a dedicated one (which we call 1:1). If you've enabled port forwarding but you're still connected with 8:1 after 15mins, then something may have gone wrong with this process; but if you are connected with 1:1, then this isn't the issue.
Message posted on 17 Jan 2025 10:52 PM
Even though my ratio is 1:1 , i still ports are not responding. which are added to the port forwarding.
Message posted on 22 Feb 2025 12:27 PM
I am having the same issue - were you able to find a solution?
Message posted on 23 Feb 2025 11:38 PM
Yes i got it to resolve by asking sky to turn off MAP-T
