Discussion topic: My wifi speed keeps dropping low to none.
This message was authored by: Atip
My wifi speed is very rarely up to speed.
The speed keeps dropping very low and even dropping completely out.
This issue has been like it from installation, but it has got worse over the past week.
Re: My wifi speed keeps dropping low to none.
@Atip Have you ever run the service checker to see what sky think off your Line. The link is below if you wish to do so.
This should determine if there's an identified fault affecting multiple households.
