Discussion topic: My wifi signal is very slow
Message posted on 22 Nov 2025 09:00 AM
The signal is really poor at the back end of the house. Kitchen and bedrooms are dreadful. Have you constantly turn off and on devices. Really unhappy with my move to sky as Fibrus was much faster and I never had a problem for half the cost! I e upgraded to your best and still struggling for good connection. Please assist!
Message posted on 22 Nov 2025 09:29 AM
Re: My wifi signal is very slow
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
Message posted on 22 Nov 2025 10:29 AM
@Skyuser6847 What hub did you have when you were with Fibrus for the connection, and what are you using from sky hub wise?
