Discussion topic: My wifi is slow on every devices
Message posted on 27 May 2025 11:47 AM
Re: My wifi is slow on every devices
I have - only connected devices are my work laptop, tv, phone, robot vacuum machine and pc but this is not a lot right? 😕
Message posted on 27 May 2025 11:50 AM
* sorry I meant they struggled - and it was a new flat I've moved in and they had to connect the internet cable from outside to inside flat entrace door cable hub etc. I don't really know how he did it but he set up Master socket 5C on my flat wall as well
Message posted on 27 May 2025 12:19 PM
I presume there's no solution for this? 😭
Message posted on 27 May 2025 12:23 PM
If you requestef 80Mbps then the fact that there were issues setting up the broadband may indicate why you're only getting 40Mbps. Also if you jeep resetting the hub that may fool the system into thinking theres a fault. Either way call sky on 150 from your sky landline or
Contact sky as below
Follow the link and choose need more help
https://www.sky.com/help/home/
If in the Republic of Ireland go to the bottom of the page and change the flag to Republic of Ireland
