Discussion topic: My wifi/Internet is dropped out and sky checks saying its OK! But it's not working..
This message was authored by: DORISBB
Wifi has been dropping out lots. And has done so again this afternoon. Did the sky checker via mobile 4g and says all is OK, but my box only has 2 green lights on left and right and no middle. Can anyone help ?
Re: My wifi/Internet is dropped out and sky checks saying its OK! But it's not working..
@DORISBB
For a ‘no broadband’ issue, if you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
