Discussion topic: My tv glass keeps going off says issue with broadband
This message was authored by: Jomo20
Message posted on 16 Apr 2024 03:32 PM
Internet keeps going off, I have sky glass so it keeps goin off
Find out more
Message posted on 16 Apr 2024 04:51 PM
Re: My tv glass keeps going off says issue with broadband
@Jomo20 The first step is to log into the My Sky app which works overca mobile connection and run the connection test as thst will check if therevis a known fault and if the hub is connected it will test thst connection and can offer to book an engineer to check everything. If it doesnt give Sky a call but things are pretty budy as the recent bad westher has caused loads of similar faults unfortunately.
