4
This discussion topic has been answered Discussion topic: My sky max WiFi won’t reach the other side of the room
This message was authored by: Tysonvolvo
Any ideas. My new sky max WiFi box won't even reach the other side of the room !!!! It's really annoying my smart plus attached to Alexa won't turn the light on she says no WiFi signal is being received. Now she is approximately 18ft away from the plug and 15inches away from sky max box  it keeps going in and out of signal and I have to keep setting them up.
This message was authored by: Mr+Flibbles+86 Answer
Re: My sky max WiFi won’t reach the other side of the room
We are still looking to help you. If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
@Tysonvolvo
With a white Max Hub you may need to reduce the wireless security level from WPA3 to WPA2-PSK using the Hub settings in the My Sky app.
You can use the same settings to temporarily disable the 5Ghz WiFi band: remember to re-enable it afterwards if you do this.
This message was authored by: Greenfingers001
Hi there @Tysonvolvo , I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Avatar for Tysonvolvo
Hi no even as I speak my WiFi is not reaching my front bedroom enough for my cctv. I have tryed and tryed   I go up set it up which takes ages to get signal it works mostly for a couple of hours then down it goes again.
