Discussion topic: My sky broadband is not connect, cable doesn’t fit
This message was authored by: Nomasomi
Message posted on 10 Jun 2025 07:47 AM
My sky is not connected, cable doesn't fit
Message posted on 10 Jun 2025 07:58 AM
Re: My sky broadband is not connect, cable doesn’t fit
@Nomasomi Where are you trying to connect the cable to, the electronic version of how to connect a hub is below, use the yes i have a landline as it does show all the options and ignore the plug in a phone part if you do not need to do so.
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
