Discussion topic: My sky box won't connect to WiFi
This message was authored by: Bigjohng
Message posted on 02 Sep 2025 09:04 PM
My sky box was connected to wi fi but today it disconnected and won't connect again and the router is the other side of the room and don't have a long enough cable to use wired
Find out more
Message posted on 03 Sep 2025 07:52 AM
Re: My sky box won't connect to WiFi
@Bigjohng reboot the Sky hub by cutting tge mains power for a few seconds as thst may dort the problem as maybe reboot the Sky box. If it doesnt then go into the network settings and reconnect the unit by following the instructions there.
