Discussion topic: My purple wire connected to open reach has broke
This message was authored by: Fazz7866
Message posted on 15 Sep 2025 11:05 AM
Good morning guys
my autistic son has broken the wire which was connected to my sky modem and to the opennreach ether port . I need to replace the wire but have no clue what wire to order . I need to replace it today as I'm working and need it for my job any help would be greatly appreciated thanks
Message posted on 15 Sep 2025 06:44 PM
Re: My purple wire connected to open reach has broke
@Fazz7866 You are looking for a standard RJ11 to RJ11 cable connection off the length that you require to replace the damaged cable if that is the standard one from sky with the purple plugs at both ends!
