13
This discussion topic has been answered Discussion topic: My new build has an openreach fttp box but sky says unavailable
This message was authored by: Hughjass112
My new house has the box, its not switched on so i dont know if thats why.
All providers say broadband is currently unavailable yet there is a new box installed. Is this normal?
Re: My new build has an openreach fttp box but sky says unavailable
@Hughjass112 wrote:
"We cannot determine broadband availability at this location. This may be a new address to which connectivity is not yet complete"
Unfortunately that would probably mean you are waiting for Openreach to complete any physical work required upstream, Openreach / BT Wholesale to populate their system, and then ISPs to dredge into that to add the address to their sales list.  As a full-fibre new build there won't be any option for a copper circuit in the interim.
@Hughjass112
Developers will often work alongside openreach in anticipation that when the houses are fully registered that openreach will take over
@Hughjass112
If you enter the new builds full postal address below and post the table and notes after removing your address from the image
Avatar for Hughjass112
@Hughjass112
The developer needs to register the homes so that openreach regards them as gold addresses. Then they can proceed
Is the box definitely an openreach ont
Its one of these boxes
@Hughjass112
Is there any on site representative for the developer/estate agent that you could enquire through
Theres some builders but they arent exactly tech savvy
@Hughjass112 The agent or builders rep should be able to give you further information.
Either way it sounds like Openreach have not finished work yet or your address has not been correctly registered with the database so you could be in for a lengthy wait. I would recommend getting some sort of mobile hotspot organised to keep you going.
I am NOT a Sky Employee
 this is it. Doesn't this mean it's connected?
@Hughjass112
Green PON should indicate there's an upstream signal. Unfortunately no ISP can resell broadband service until the wholesale database is updated.
So what should I do?
This message was authored by: KScott
Get a mobile network broadband provider that works over 5g until the service is turned on and shows as available in your area. U will probably get a flyer through the post from whomever is the major installer in the area.
for me that was city fibre who installed the local fibre and then I went with giganet as my ISP who arranged for FTTP connection with city fibre engineers. Both teams arrived on same day. Ran in fibre cable Alongside existing copper phone line. They were here about 2/3 hours and I was up and running at +900mb/s over a measly 15mb through sky despite there guaranteed 40mbs.
