Discussion topic: My new broardband will not connect to televison
Message posted on 23 Oct 2024 10:35 PM
My WiFi will not connect to television
Message posted on 24 Oct 2024 10:01 AM
Re: My new broardband will not connect to televison
@Debs26 Have you tried to factory reset the TV like it was just coming out of the box to see if it will then connect to the broadband?
Message posted on 24 Oct 2024 01:19 PM
Yes I have tried a reset, the only thing that seems to work is b using hotspot off my phone. Which is not the greatest solutions, but all I have.
Message posted on 24 Oct 2024 01:26 PM
@Debs26 Is it a white router that you have from Sky or is it black?
Message posted on 24 Oct 2024 06:04 PM
I us a white router my black one was fine.
Message posted on 24 Oct 2024 06:19 PM
@Debs26 try switching the WiFi security setting from WPA3T to WPA2 which some TVs wont connect tomthe newer more secure standard. Setting is in My Sky/Product Options/ Sky Max hub/advanced settings/WiFibsecurity.
Message posted on 25 Oct 2024 10:33 AM
Thank you so very much that seems to have worked 🙂 xxx
