Discussion topic: My internet is not working but sky is saying everthing looks ok
This message was authored by: Nointernet6
Re: My internet is not working but sky is saying everthing looks ok
@Nointernet6
If you have broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
