Discussion topic: My internet has been cutting in and out for the past few days.
Message posted on 19 Oct 2025 10:37 PM
Hello sky
Message posted on 19 Oct 2025 10:43 PM
Re: My internet has been cutting in and out for the past few days.
Message posted on 19 Oct 2025 11:29 PM
Same mines cut out 3 times in the last couple hours it's cut out right now
Message posted on 20 Oct 2025 01:31 AM
- my internet is down now
Message posted on 20 Oct 2025 01:32 AM
is there an outage in Slough
Message posted on 20 Oct 2025 05:36 AM
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
You can use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
wfh: Remember Sky broadband being discussed here is a domestic service and whilst it's fine for those customers working from home to use it, they won’t receive additional or quicker support.
