Discussion topic: My hub will not connect any of my WiFi devices. Says the password is incorrect
This message was authored by: Djsmith965
Message posted on 30 Jul 2024 09:29 AM
As above. Hub says that the password to connect wireless devices is incorrect. Hub is connected to my wired devices and will connect to other devices using the WPS button. Have tried pressing the reset button for 20 seconds and that does not work neither does turning the hub off and on again
Find out more
Message posted on 30 Jul 2024 12:23 PM
Re: My hub will not connect any of my WiFi devices. Says the password is incorrect
Are you sure you are typing the correct wireless key from the sticker on the hub? Note they are case sensitive & some symbols look like letters/numbers & vice versa.
I am NOT a Sky Employee
