5
This discussion topic has been answered Discussion topic: My hub is working but I have no wifi
This message was authored by: WE11MUZ
My hub is on and according to the internet check I'm connected but I have no WiFi anywhere no device is getting a signal? Is there a problem with sky or me?
Re: My hub is working but I have no wifi
There appears to be an issue with some hubs not showing the SSID if tgst applies reset your hub as folows
Try to reset your Sky hub which should make the SSID visible.on the newer white hubs hold in the wps button on the right hand edge for at least 20 seconds until the led flashes and rdlease. On the black hubs hold in the reset pin until the power led flashes shich takes 10 to 20 seconds.
This message was authored by: Belfast87
Same problem here.
This message was authored by: WiSky1
Same here.
just got sky yesterday and on the second day itself Broadband isn't working
diagnostics states both broadband and WiFi are fine
Avatar for WE11MUZ
Thank you so much!!! I only just got the router and I didn't know there was a side button on it. It is working fine now so great advice and thanks again
This message was authored by: StephenF
Try the solution suggested by Chrisee - I had the same problem (1 week after installation!) and it worked for me.
