Discussion topic: My hub has just stopped working
Message posted on 23 May 2025 03:50 PM
My hub has just stopped working and showing an orange light
Message posted on 23 May 2025 04:02 PM
Re: My hub has just stopped working
@Lymme
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
