Discussion topic: My broadband works then stops
Message posted on 08 Feb 2025 04:19 PM
My broadband keep working then going off and if it keeps happening I'll be changing supplier because I have been intouch before and nothing has been done
Message posted on 08 Feb 2025 04:21 PM
Re: My broadband works then stops
@Corey12
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
