Discussion topic: My broadband isn’t working
Message posted on 03 Feb 2025 07:51 PM
I have successfully managed to connect my hub and get wifi....for about 2 minutes and then it cuts out and intermittently cuts in and out all the time. Your service checker says everything is fine but it clearly is not
Message posted on 03 Feb 2025 08:03 PM
Re: My broadband isn’t working
@Anna-home
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
