Discussion topic: My broadband isn't working I have no internet connection
Message posted on 09 Sep 2025 12:49 AM
I have reset my hub but all WiFi is down in my property
Message posted on 09 Sep 2025 04:51 AM
Re: My broadband isn't working I have no internet connection
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
If your broadband still isn’t working after 7am use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
NOTE: I only provide help on the forum boards and NOT via Direct Messaging so DMs are switched off
