Discussion topic: My broadband is so bad I have to disconnect and use 4/5G often.
Message posted on 14 Aug 2024 09:31 AM
Upgraded broadband and it's worse than before. Simple websites don't load, often drops and there's no connection. Have to disconnect and use 4/5G. Cannot get through to an actual human being to discuss it.
probably won't be a customer for much longer, which is a shame because I have been one for a very long time!
Message posted on 14 Aug 2024 10:32 AM
Re: My broadband is so bad I have to disconnect and use 4/5G often.
@Danzzz78 Did Sky change the router you have to another router after you upgraded?
Message posted on 14 Aug 2024 10:35 AM
Hi,
No, it is the same router as before! Should I have got an upgrade? All they sent was a wire...
FYI - I have ASUS extenders from the router.
Thanks.
Message posted on 14 Aug 2024 10:36 AM
@Danzzz78 What colour is your router from Sky black or white?
Message posted on 14 Aug 2024 10:49 AM
Hi,
it's a black one. SR203.
thanks
Message posted on 14 Aug 2024 10:54 AM
@Danzzz78 Could you please post your router stats following the link below.
Message posted on 14 Aug 2024 11:05 AM
Message posted on 14 Aug 2024 11:21 AM
@Danzzz78 If you look at the bottom of the page that you posted it says " Show Statistics " can you click on it and screenshot that please as what you posted is not what we are looking for.
Message posted on 14 Aug 2024 11:28 AM
Message posted on 14 Aug 2024 11:43 AM
@Danzzz78 Has the devices that you are talking about has this happened in the past 6 days going to 4g/5g?
Message posted on 14 Aug 2024 11:48 AM
It's been happening since the switch over, but I gave it the recommended 14 days settling in.
whether and app or a website or even iCloud email, it gets to the point where is wont load and as soon as I turn the WiFi off it loads in the 4/5G perfectly.
i know all the signs point to fast download/upload but that's simply not the real life usage scenario ☹️
Message posted on 14 Aug 2024 11:56 AM
@Danzzz78 Looking at the router stats it is saying no drops at all. Don't know if this could be down the the private relay that Apple does use on their devices and maybe someone can chime in to what the problem might be and a solution to help.
