Discussion topic: My broadband is continuously dropping in and out.
This message was authored by: Nicci9
My broadband keeps dropping, I mean every couple of minutes.
when I go into setting to check the status it says it's connected to the internet but not my router.
when I call Sky it says there is an issue with my router.
Ive followed all the steps but it keeps dropping.
it's difficult to use MySky as I live in an area where WiFi isn't great.
i need this issue resolved ASAP.
thanks
Re: My broadband is continuously dropping in and out.
@Nicci9 Could you please post your router stats following the link below.
Avatar for Nicci9
Status of your broadband and WiFi network
Broadband Connected
WiFi Enabled
WiFi Network Name (SSID) SKYU67GC
WiFi Network Visible Yes
Current WiFi Channel 6 (2.4 GHz), 36 (5 GHz)
WiFi Encryption WPA2-PSK
VoiceConnected
Devices connected to your home network
Device Name MAC Address UNKNOWN 36:f5:f4:61:e2:1f RingDoorbell-71 9c:76:13:7a:c3:71 SKY+HD d0:58:fc:86:54:32 UNKNOWN c0:91:b9:0f:9b:93 UNKNOWN 7c:d5:66:77:e8:1e amazon-65bbe1146 68:db:f5:7e:1f:b6 UNKNOWN 52:8a:82:f8:e0:62 UNKNOWN f0:a3:b2:80:70:1f UNKNOWN 72:c6:21:d7:66:99 SKY+HD 78:3e:53:b9:51:82 SKY+HD d0:58:fc:95:81:72
Avatar for Nicci9
@Highlinder I think I've sent the correct details 🤷‍♀️
@Nicci9  That is  not your router stats, you have to follow the directions to the end.
Avatar for Nicci9
It won't let me sign in, it's continuously asking me to sign in
@Nicci9  Which router do you have from the picture below.
Avatar for Nicci9
@Highlinder I have the Sky broadband router
@Nicci9  So follow the what it says to login and you should be able to get to the information.
