		Discussion topic: My WiFi name with my new hub is showing name
	This message was authored by: Paul4217
		Message posted on 09 Jul 2025 01:52 PM
WiFi name showing wrong WiFi name
Find out more
		Message posted on 09 Jul 2025 01:59 PM
							Re: My WiFi name with my new hub is showing name
If you have a new hub then it will come with a new wifi network name but you can login to it and change it to what it was before:
https://www.sky.com/help/articles/find-and-change-your-wireless-password
In a browser address bar, enter 192.168.0.1.
Select Wireless or WiFi.
Enter the default username admin
And depending on which hub you have, the password is either sky or your WiFi password.
You can then change the wifi name and password here.
