Discussion topic: My WiFi isn’t working properly sky is terrible it keeps cutting out circling all the time
This message was authored by: ALpilley
I would like the wifi to work it's so frustrating always been terrible since I upgraded it
Re: My WiFi isn’t working properly sky is terrible it keeps cutting out circling all the time
@ALpilley
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
