Discussion topic: My WiFi is not working it has a orange light on “LOS”
This message was authored by: Lekssss
Why is my wifi not working how do I get it to work?
Re: My WiFi is not working it has a orange light on “LOS”
@Lekssss
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
@Lekssss Have a look again, are you sure that the LOS signal is not RED in colour? No light on the Fibre so from exchange to home, sky service checker may have a not if area wide fault!
