Discussion topic: My WiFi drops out at night
Message posted on 22 Aug 2024 03:05 PM
Every night my WiFi cuts out.
Message posted on 22 Aug 2024 03:08 PM - last edited: 22 Aug 2024 03:09 PM
Re: My WiFi drops out at night
Do you have Sky Q television?
If so, the likely cause is the local WiFi signal dropping when the Q boxes go into their Eco mode.
https://www.sky.com/help/articles/using-the-standby-settings
Message posted on 22 Aug 2024 05:51 PM
Yes I have sky Q.
I have switched it off and back on 5 minutes later. Will see if that helps. I do not expect to loose connection at night. It drops out from all our devices, phones, cameras, iPads
Message posted on 22 Aug 2024 05:54 PM - last edited: 22 Aug 2024 05:54 PM
You need to change the standby settings as described in the link I posted.
