Discussion topic: My WiFi does not work for social media apps
This message was authored by: Jeronimo1
I don't know why me an my brother's WiFi is not working well on our phones, we can't use our social media apps and apps such ash WhatsApp with the WiFi, we are forced to use our data for that, if anyone's has a number to call or a solution I'll be waiting.
thank you
Re: My WiFi does not work for social media apps
@Jeronimo1
What hub do you have?
Are you both new to sky broadband?
@Jeronimo1
Typically that's because Sky Broadband Shield is still running on its default age setting.
This message was authored by: Sush21
Mine isn't working  either. Just moved into new home so sky is new
@Sush21 Logon to your account, check and adjust the Broadband Shield to what you need!
This message was authored by: davewill58
Have a look at my post just a couple above re Sky Broadband and Broadband Shield Settings
Hopefully by following these steps you will get things sorted
@Sush21 Linked for @davewill58 post makes it easier for you to find!
Sky Broadband Shield and WhatsApp Problems | Sky Community
