Discussion topic: My Wi-Fi is not working. It keeps on saying no Internet connection.
Message posted on 15 Mar 2025 06:30 PM
It keeps saying no Internet connection on my device devices.
Message posted on 16 Mar 2025 02:57 AM
Re: My Wi-Fi is not working. It keeps on saying no Internet connection.
Message posted on 16 Mar 2025 05:52 AM
@Ramzess82 Any outage between midnight and 0700 could be overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it's not working later use the below link to check to see if there are any problems or outages nearby
