Discussion topic: My TV will not connect to wi-fi
This message was authored by: Joyce65
TV in my dining room will not connect to WiFi, tried moving it beside sky box and the only way it will connect is through the ethernet cable which is not an option
Re: My TV will not connect to wi-fi
@Joyce65 do you have a white Sky Max hub if so try changing the WiFi security level from WPS3T to WPA2 in the advanced section of the Sky Max hub settings in the My Skyapp. Some TVs seem not to like the higher security setting.
