Discussion topic: My BB speed is rubbish 22mbps
This message was authored by: mrtvercetti2265
BB speed not as it should be
Re: My BB speed is rubbish 22mbps
@mrtvercetti2265
If the broadband has become slow see this link
@mrtvercetti2265 a lot depends on the line Sky are using. 22Mb/s over a long copper line may well all it can support. The other major issue is are you measuring speeds at the hub or at a device connected by WiFi as WiFi speeds depend on the layout of your home and what it is built out of.
