Discussion topic: Moving home- ...may need to make changes ...
Message posted on 02 May 2024 11:31 AM
I'm moving home and want to transfer my contract to new address. I checked availibity for the address and it's available, but there is note "You may need to make changes to your broadband package.", but I can't find what changes. Who and how can I contact to got the information, please?
Message posted on 02 May 2024 11:52 AM
Re: Moving home- ...may need to make changes ...
Putting the address into the BT Wholesale Availability Checker should indicate which provisioning type is applicable.
Message posted on 03 May 2024 03:13 PM
Message posted on 03 May 2024 03:20 PM
If there is nothing above the fttp on demand then you will be on a very long copper adsl to the exchange of 2Mbps if i read correctly
Message posted on 03 May 2024 03:27 PM
If you could post the top part of the table, that would be useful.
As @cookiemonsteruk indicates, it may be that your current contract is for a faster product than can be supplied at the new location.
Message posted on 03 May 2024 03:53 PM
Also as your speed ,if fttc isn't available , will never exceed the 10Mbps downstream ofcom have mandated please read below for ofcoms universal service obligation :-
Message posted on 05 May 2024 08:32 AM
Message posted on 05 May 2024 08:36 AM
This is my current home
Message posted on 06 May 2024 07:58 AM - last edited: 06 May 2024 08:20 AM
That shows you can currently get average FTTC ('Superfast') at the address, but not FTTP or G.fast ('Ultrafast')
Message posted on 06 May 2024 08:02 AM
@TimmyBGood i read it as the first image was for the new address and the second for the current address
@Jann410 could you clarify . Thanks
Message posted on 06 May 2024 08:06 AM
If that's the existing address and there's no similar listing for the new one then as @cookiemonsteruk indicates it's a very significant downgrade, and these days that should really be reflected in the price of the property (purchase or rental).
Going from average FTTC to poor ADSL is likely to be unpleasant: note in particular that the very limited outbound speed makes ADSL largely unsuitable for working from home.
Message posted on 06 May 2024 08:09 AM - last edited: 06 May 2024 08:11 AM
And note that FTTP on Demand is essentially irrelevant: that's a scheme where the householder pays some or all of the real cost of an optical installation at an address which is outside the commercial FTTP rollout, and this is typically unfeasibly expensive.
Message posted on 06 May 2024 08:15 AM - last edited: 06 May 2024 08:18 AM
I'd also point you to this resource:
https://www.connectingdevonandsomerset.co.uk/
Having stayed a couple of times in that part of the world in a property served by point to point WiFi beaming across a substantial valley I can confirm it's a viable option as an alternative to FTTC, but note that this is specialist infrastructure with a substantial lead time, and not available from mainstream ISPs.
Message posted on 06 May 2024 08:24 AM
Just to be clear, the new address appears to have ADSL at 4Mbs inbound and 0.4Mbs outbound, which would put it in the lowest few percent of broadband speed in the UK and is pretty much unviable for modern life. With no other internet use that might support one incoming SD television stream or one very bad outbound video call.
Message posted on 07 May 2024 09:10 AM
Yes. First image is new address and the second one is new.
There is already Internet on the new address and they use it for streaming (Amazon prime)
