Discussion topic: Moved house, previous owner taken openreach box cable!
This message was authored by: GKTurner
Hi, anyone know where I can get a power cable for the openreach box on the wall? Activation today and have just set it up (as suggested. but wish I did it sooner!) and there is no power cable. Very frustrating as WFH is a bit difficult!
Found a cable from my air purifier works, but obv don't want to burn my house down with the wrong cable!
Thanks!
This message was authored by: FLC
Re: Moved house, previous owner taken openreach box cable!
Assuming the PSU you're using is 12V, at least 1A & a good fit, it should be fine as a temporary measure.
You'll have to report it to Sky to get a replacement.
