Discussion topic: Mobile phones keeps being disconnected from broadband using up my mobile data!!
Message posted on 17 Aug 2025 12:53 PM
Message posted on 17 Aug 2025 01:01 PM
							Re: Mobile phone keeps being thrown off my home WiFi.
Apart from these two phones do you have any other devices connected to your Wifi and if so do this also disconnect at the same time ?
Message posted on 17 Aug 2025 01:28 PM - last edited: 17 Aug 2025 01:29 PM
							Re: Mobile phones keeps being disconnected from broadband using up my mobile data!!
@bobby+boo What is the sky Hub version that you are using on the system! The black SR203 Sky Broadband Hub or the white SR213 sky Max Hub!
Message posted on 17 Aug 2025 02:01 PM
The black one - fibre
Message posted on 17 Aug 2025 02:06 PM - last edited: 17 Aug 2025 02:15 PM
@bobby+boo That hub the old trusty black SR203 is pretty rock solid wi-fi wireless wise, cannot say the same about the newer phones and versions off the software on those, so first off, just switch the mobile data off on the phone all together, see how the mobiles work just on the straight wireless wi-fi connection to start with!
Flagged up the multiple postings, so also good if you could answer @caesarome 's question regarding other device drop off's, gives the bigger picture!
Message posted on 17 Aug 2025 02:10 PM
@caesarome User has created multiple postings, have started with answer on the other!🙄👍
Message posted on 17 Aug 2025 04:24 PM
Thanks @JimM1 , I have merged and removed.
Message posted on 21 Aug 2025 09:23 PM
No turning off mobile data actually prevents my mobile connecting to the Internet!
Message posted on 21 Aug 2025 10:15 PM
@bobby+boo If you have the mobile phone connected and enabled to the sky wireless wi-fi, then mobile off will not have any effect as the broadband is supplied over the wireless wi-fi connection!
