Discussion topic: Mobile disconnects from WiFi overnight
This message was authored by: Spionfox
For the past three mornings I have had to re-sign in to WiFi on my mobile phone (Samsung A33 5g). None of my other WiFi connected products (tablet, smart plugs/speakers etc) are affected and remain connected. It is just the phone and my wife's phone (same model) is also affected. Previously to the past three days I haven't had a problem. Anybody got any ideas? Thanks.
Re: Mobile disconnects from WiFi overnight
@Spionfox check that the phone is set to trust your home wifi connection as a secure network.where the setting is varies.
This message was authored by: ARNL81
We are also having this issue in our house. All four mobiles disconnect overnight and do not automatically reconnect. Nothing else that is connected to the WiFi is affected. Does anyone know how to stop this from happening? It's been happening for the last 5 days now.
Avatar for Spionfox
  • Thanks for reply, but didn't resolve problem. I notice that another person is also experiencing this issue so could be a Sky issue?
@Spionfox @ARNL81  All FW issue update going on so heads up currently SKY are aware off it now solution presently unkown. This may or may not be causing you mobile issue so heads up but suspect it might be kind of related!
This message was authored by: hgwv
My Samsung does the same, very likely due to the current issue where router firmware is changing every night, so the phone thinks it's a "new" router and needs user permission to reconnect.
