Discussion topic: Missing ONT power cable in new home
This message was authored by: JH68HRH
I have recently moved home and transferred sky broadband but found that the ont power cable is missing. How do I obtain a replacement cable?
Re: Missing ONT power cable in new home
@JH68HRH  I'll never understand why a previous resident would take a power cable, but sadly this seems to be a common occurence.
You'll need to contact, these are the current methods for contacting Sky. (Depending on your reason for making contact some methods will be more appropriate than others) …
🔶📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: if your services are restricted due to a missed payment phone contact is unlikely to work.
🔶online help via this link
https://www.sky.com/help
🔶 Sky Assistant should also be available via
🔶Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Note If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required.
Avatar for JH68HRH
Thank you. I appreciate the advice.
