Discussion topic: Massive data usage
This message was authored by Brugie58 This message was authored by: Brugie58
Massive data usage
Hi All
This may well be a fault on the Sky site, but this month I have used over 11,000GB of data !
The average is about 2000GB for previous months
This has happened since I changed from FTTC to FTTP and I now have a mini box running as well
According to sky, the mini box will consume data if it's not put into standby
I turn the TV on when I go to bed and set the time for whatever time, it then turns off, but the mini box is still running until the small hours (Yes, it's in Eco mode), so it's still using amount of data
But 11000GB this month does not seem possible
Anyone else have this problem/data usage blip ?
Brugie58
Re: Massive data usage
So, an update
Looks like an error to me on the Sky page, this can't be possible
As a test the mini box has been not used for 2 weeks
