Discussion topic: Main Sky Q box won’t connect to sky router
This message was authored by: J7nno
Message posted on 08 Feb 2025 05:46 AM
Been working fine but main sky q box has lost WiFi connection and won't connect by wps.
Have tried resetting everything to no avail
Find out more
Message posted on 08 Feb 2025 07:13 AM
Re: Main Sky Q box won’t connect to sky router
@J7nno acreboot can help and you may find connecting the Qbox using the non-Sky hub option - choose the SSID and enter thecpassword - works when WPS doesn't especially for the white Sky hubs. If it still wont connect it couldcsimply beca range issue if so talk to Sky.
