Discussion topic: Lost broadband connection around 17.45
This message was authored by: Mikey_H
I've been using my broadband all afternoon but connection was lost around 17.45. 2 red lights on router. Have turned everything off, unplugged and reconnected but all still the same.
Re: Lost broadband connection around 17.45
@Mikey_H   First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
@Mikey_H
Avatar for Mikey_H
Hi, thanks.
Sky are now reporting a problem in the area.
Very strange that their "checks" didn't reveal any problems in the area or with my equipment!
It just makes you wonder if the checks actually work!
