Discussion topic: Loss of wifi
Message posted on 31 Jul 2025 11:08 PM
Loss of wifi
Keep losing the wifi signal intermittently today (PE21 area) anyone else having issues?
I have done the service checker and it says all is good, however currently running on 5g in my home where I pay good money to have wifi
Message posted on 01 Aug 2025 03:11 AM
Re: Loss of wifi
@Meaf3105
If your Sky broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
