Discussion topic: Loss of service on fibre
Message posted on 08 Jul 2025 01:47 PM
I have a LOS warning g and have lost all internet at home.
I work from home and this is urgent
Message posted on 08 Jul 2025 01:49 PM
Re: Loss of service on fibre
@Lee82monk
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
