Discussion topic: Loss of power issue
This message was authored by: Pins79
Loss of power issue
LOS is out for a few nights now, losing signal on phones and tv. LAN is flashing
Re: Loss of power issue
@Pins79 All sounds good, the LOS should be out... When it faults will go RED and that you do not want to see ever!
Power and Pon both solid Green, Lan will flash with data back and forth to the Hub/ONT and the LOS allways out!
Something else is going on if it's not your ONT!
