Discussion topic: Loss of Internet connection
This message was authored by: MichaelBrennand
Tried to reset router but only the two oueter lights turn dreen with the middle light stuck on orange
Re: Loss of Internet connection
@MichaelBrennand  Resetting your router won't help if there is a fault.
First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Avatar for MichaelBrennand
Awaiting a response from sky.is there a number I can call to speak to a human?
This message was authored by: IN3
Loss of internet connection all day!! Tried reset to no avail
This message was authored by: Yusufk
It happens every day at least once. Connection loss the lights turn amber then turns green again. But happens every day. What is the problem?
