Discussion topic: Looking to set a mesh system to work with sky full fibre
This message was authored by: Ashley+Cox
I'm looking to upgrade to a mesh system.  I currently have Sky full fibre 500.  What have people used and what experiences do they have.  I'm looking for soemthing that's easy to install yourself and use and that gets decent wifi speeds and doesn't break the bank.  Would I need to change the router as well?
Re: Looking to set a mesh system to work with sky full fibre
Hi @Ashley+Cox
You can get mesh systems that plug into an existing routers like your Sky hub or ones that have their own router to use.
Personally I have found Asus Ai mesh to be good.
I am NOT a Sky Employee
@Ashley+Cox Small and compact, not a speed merchant but well capable and you can go read reviews about it. Gives you the idea.
ASUS ZenWiFi XD5
Hands on: I tried the Asus ZenWiFi XD5 - see what I thought of this Wi-Fi 6 mesh | TechRadar
