4
This discussion topic has been answered Discussion topic: Longer power lead for SKY broadband router SR204
This message was authored by: GoQuentin
Hi, I need to find a longer power lead for SKY broadband router SR204, but I can only find one for SR203 router, see below:
https://www.ebay.co.uk/itm/143910697084
Do you know if Power supply unit is same between SR 204 and SR203?
Re: Longer power lead for SKY broadband router SR204
@GoQuentin
As @Chrisee indicates, as far as we know the 204 is the 203 with a G.fast modem
@GoQuentin the normal solution is to use a mains extension cable as all Sky Hubs come with cables the same length. The SR204 is an identical unit to the SR203 except for the modem so I would expect the power units to also brvthe same. Whether that unit is truly compatable is unknown but if you damage your SR204 using it Sky may charge you.
Avatar for GoQuentin
@Chrisee , thanks for the prompt response and understand/accept  the risk involved here.  I am interested in the PSU PIN lay out if they are the same for  both routers, please can you confirm the same.
@GoQuentin
@GoQuentin no idea I am a customer just like you.
