05 Oct 2023 10:48 AM
05 Oct 2023 11:46 AM
Posted by a Superuser, not a Sky employee. Find out moreWhat device & browser are you using?
Credentials should be as follows;
Username: admin
Password: the default WiFi password printed on the sticker on your hub
05 Oct 2023 10:51 AM - last edited: 05 Oct 2023 10:51 AM
Posted by a Superuser, not a Sky employee. Find out more@Hroff Which hub do you have?
05 Oct 2023 10:58 AM
Hi. I've got the Sky Broadband hub. Cheers
05 Oct 2023 11:02 AM
Posted by a Superuser, not a Sky employee. Find out more@Hroff Tr resetting your hub.
How you reset your hub depends on which hub you have.
Good to know: This will reset all your hub's setting including your WiFi password, so if you've changed it from its default you'll need to change it again.
05 Oct 2023 11:05 AM
Great. I'll try that. Haven't changed any setting yet. Only went live yesterday. Thank again. I'll let you know how I get on.
Geoff
05 Oct 2023 11:30 AM
Username: admin
05 Oct 2023 11:48 AM
Posted by a Superuser, not a Sky employee. Find out more@Hroff Are ou typeing the password as shown using both lower & upper case as per the characters showing on the Sky hub
06 Oct 2023 08:19 AM
Hi James.
I'm in at last. Think I was using the incorrect log in details. I had seen somewhere log in as admin and sky as the log in details. You were spot on with admin and the WiFi password.
Thanks again for all your help. Cheers
Geoff
06 Oct 2023 08:25 AM
Posted by a Superuser, not a Sky employee. Find out more@Hroff that was why you were asked which hub you have you were using the details the older hubs use Sky added a bit more security to the SR203.
06 Oct 2023 08:28 AM
Hi Chrisee.
Thanks for that. I'm in now I'm using the correct log in info.
Thanks again
Geoff
