Discussion topic: List of devices connected to wifi has duplicates
Message posted on 09 Nov 2025 05:57 PM
When I check the list of devices connected to my wifi, there appear to be duplicates. Why is this? E.g. we have 2 iphones and it lists 3. Also a Macbook is listed twice.
I haven't switched the (complicated) password off so I presume it's not a neigbour hacking me! If it is, how can I disconnect them and change the password?
Message posted on 10 Nov 2025 02:40 PM
Re: List of devices connected to wifi has duplicates
@RMaz The help link you need is below from sky!
Find, change or reset your WiFi password | Sky Help | Sky.com | Sky Help | Sky.com
Message posted on 10 Nov 2025 05:24 PM
@RMaz Just a thought, items can appear twice if they are connected to both the 2.4GHz and the 5GHz bands at the same time (I think!)
Message posted on 10 Nov 2025 08:40 PM
Please disregard my previous response, talking out of my nether parts!
This might explain it however!
Message posted on 10 Nov 2025 09:05 PM
Sounds like a rotating MAC address, try this.
Apple devices generate rolling MAC addresses, each time they re-connect they generate a diffrent MAC address, as the lease is allocated by your router you may see the old one and the new one until the IP lease expires.
In General settings, WiFi, touch the blue 'i' in the circle next to the connected WiFi name, change the 'Private WiFi Address' to 'Fixed' this will stop the iphone from creating new MAC addesses when it re-connects to that WiFi Station.
On your MacBook, the process is similar, under WiFi Settings.
The idea is it supposed to stop your Apple devices being tracked on public WiFI stations, where the Private WiFi Address will be set to Roatating, by default.
I remember the Internet starting!
Sky Full Fibre & Virgin Media XGS-PON, with automatic failover using DrayTek multi WAN router.
Sky Q, which will be sadly missed when they decide to kill it off!
