Discussion topic: Linksys MR7350 FTTH Ireland
This message was authored by ChrisDes This message was authored by: ChrisDes
Hi There,
Just switched from Virgin Media to Sky this month ( 1gb fibre to the home) When with Virgin, I had the super hub in modem mode and was using 2 Linksys Velop mesh units  for WiFi.
I'm wondering if I can replace the sky hub completely with a Linksys MR7350 by just plugging the ethernet from ONT into it and I can place the velop nodes around the house to create a more stable network?
I currently have two wifi signals ( one from the sky hub and the other from the mesh network) the sky wifi is currently delivering faster speeds over the mesh but I'm hoping once I consolidate into one mesh signal speeds will improve .
Re: Linksys MR7350 FTTH Ireland
@ChrisDes This post  discusses how to connect to Sky Ireland fibre services generally. The Irish services use PPOE so are far simpler then the ones Sky use in the UK. Alternatively you could simply turn off the wifi on the Sky hub
ChrisDes
Thanks Chrisee,  i saw this thread but i was wondering if anyone had used the Linksys Router - i previously purchased the TP - AC2100 but wasn't able to get it to work, assume its because the connection is PPOE
@ChrisDes
I've seen people try and fail to use a Linksys router on Sky broadband but that is due to the requirement of the DHCP Option 61 field that the Linksys doesnt seem to have. However since you are in Ireland you should be able to connect it no problem.
I am NOT a Sky Employee
ChrisDes
Thanks  @jamesn123  I'll take a punt an buy on Amazon - if it doesn't work i can always send back
