Discussion topic: Lights on my router
This message was authored by: Clr11
Message posted on 10 Aug 2025 06:29 PM
Lights on my router
I have an issue with the internet light on my router isn't even showing a light and voice light is orange. I've tried resetting and unplugging and waiting a while, still no luck though can anyone help. When doing a wifi check on my sky app says there is no problem and all looks good.
Message posted on 10 Aug 2025 06:45 PM
Re: Lights on my router
@Clr11 About the lights link and what to do when you step through the one you need!. Will be the Sky Broadband Hub for you!
