Discussion topic: Lights on hob are yellow internet notworking
This message was authored by: Paul689
my internet is not working and the light on the hub are yellow
Re: Lights on hob are yellow internet notworking
@Paul689
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
